Kirlieq
Aug 27, 2019Aspirant
ORBI45 authentication problem
My kids are trying to join each other in the new Terraria update from their mobile devices and are being asked authentication questions that I assume I have to answer as the account holder (High Scho...
Aug 28, 2019Guru - Experienced User
Retired_Member Just made me wonder why the OP is posting to the netgear forums if its an issue with Terraria. If its an issue with terraria, your response is correct. with that said, I have seen orbi act a bit wonky and asking for router login info when accessing certain sites. I haven't experienced it in a while but I have experienced it.
Retired_Member
Aug 28, 2019
plemans wrote:Retired_Member Just made me wonder why the OP is posting to the netgear forums if its an issue with Terraria. If its an issue with terraria, your response is correct. with that said, I have seen orbi act a bit wonky and asking for router login info when accessing certain sites. I haven't experienced it in a while but I have experienced it.
yes...I thought the same. Although it's a valid question, if even fact it deals specifically with the Terraria site, it probably should have been posted else where. Thanks
