kspoon
Jun 04, 2019Aspirant
ORBI50 almost no connection at all
I have recently purchased an ORBI RBR50 (march 2019). Initially it works OK, speed test on my phone connected to ORBI via wi-fi does seem to be faster than my old AC router. About 1-2 months ago, aft...
michaelkenward
Jun 05, 2019Guru - Experienced User
kspoon wrote:
Main router is connected via wire right beside my internet provider's router.
How many "routers" are we talking about here?
Is the RBR50 what you call the "Main router"?
What is the Internet provider's router? Is that the modem that gets you to the outside world, or a separate box?
If the Internet provider's router really is a router, or a modem/router, then you may want to put the Orbi RBR50 into AP mode.
kspoon
Jun 05, 2019Aspirant
Internet provider is Rogers (I am in Canada). I believe it is a modem and router combined in one. It is only one box and previously I was using AC wi-fi from that same box.
What's AP mode?
- michaelkenwardJun 05, 2019Guru - Experienced User
Not knowing the make and model number of the modem/router, it is hard to advise on the best strategy.
Do you plan to use the wifi from the modem/router as well as the Orbi?
What's AP mode?
AP = Access Point
There is support for the Orbi WiFi System, including a manual, somewhere at the end of this link:
>>>> Orbi RBK50 | WiFi System | NETGEAR Support <<<<
Find the manual for your model and read the section Use the Router as a WiFi Access Point.
