kspoon
Jun 04, 2019Aspirant
ORBI50 almost no connection at all
I have recently purchased an ORBI RBR50 (march 2019). Initially it works OK, speed test on my phone connected to ORBI via wi-fi does seem to be faster than my old AC router. About 1-2 months ago, aft...
Jun 05, 2019Guru - Experienced User
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
