PM_13
Dec 02, 2020Tutor
Orbi50 AP Mode and VLAN
Hi, On the Orbi configuration UI I see that there is an option for VLAN and I can assign it to one of the port on the back. So I am thinking of creating a VLAN and then connect the assign port t...
- Dec 02, 2020
PM_13 wrote:Hi,
I believe if you click "Help" at the bottom of the page, it will say that the VLAN capability is to support IP television. Orbi does not support the sort of VLAN's that corporate environments use to segregate different groups of user devices.
CrimpOn
Dec 02, 2020Guru - Experienced User
PM_13 wrote:Hi,
PM_13
Dec 02, 2020Tutor
CrimpOn wrote:
PM_13 wrote:Hi,
CrimpOn thanks...that was quick and painless...almost borderline humane :smileyhappy:
