thel1th
Feb 01, 2023Aspirant
Orbi50 IPv6 OpenVPN accessible?
Dear community, since I have a new fiber broadband access to the internet I did not try to use my OpenVPN from the Orbi anymore, because the new ISP only provides my router an IPv6 adresses with ...
CrimpOn
Feb 07, 2023Guru - Experienced User
Sorry to take so long..... If you've already solved the problem, I'd like to know how you did it.
IPv6 is a "learning opportunity" for me. From what I have picked up so far, it appears that placing the Orbi into IPv6 Passthrough mode should enable connections from the internet directly to specific devices on the LAN. Before investing too much time in this direction*, I wonder if you could share some aspects of the goal:
- Do the devices that you want to reach on the LAN have public IPv6 addresses?
If they do, then my impression is that connections can be made directly to each device without involving a VPN. - Are the devices secure enough to tolerate exposure to the internet? With IPv6 addresses being 8 segments of FFFF (about 3.40+38 individual possibilities), it would seem that brute force searches of IPv6 address space are unlikely. If the open port is secured with a strong password or other type of authentication, even knowing the IPv6 address would not guarantee access.
- While it appears my Spectrum connection supports IPv6 Passthrough, I have no experience with Dual Stack - Lite. Does it also support direct access to Public IPv6 addresses?
* Have considered downloading OpenVPN for Windows, configuring it for IPv6, and "seeing what happens" when I connect to this version of OpenVPN rather than the neutered version on the Orbi.
thel1th
Feb 08, 2023Aspirant
Also sorry for my late response... I was on holiday when I worked on this and now got back to work.
I tried something like a port forwarding (which I expected not to work as it is IPv4). I have a web app on my local server. I opened the port for the application on the port mappings tab.
Also I made sure that the linux container is IPv6 compatible and it had a public IPv6 address with my IPv6 Prefix and the MAC-derived local address. I forgot the name.
Expecting this would not work I tried to expose it and asked a friend to access it. He did not have success.
Requirements
- The one that I gave a try to access from outside I assigned an IPv6 address and made sure it has a public IPv6 address. But it did not seem to work. I guess because of the IPv6 filtering? I was expecting the port mapping not to work because it's IPv4-based. It did not make sense to enter it, but if you are trying out things you give all you can 🙂
I saw that Fritzboxes allow such exposure on IPv6-level. In general no device is exposed, but the ones I want to expose I would like to expose on a port-based level. - I only want to expose selected devices. I still want the functionality of a router to filter traffic.
- A lot of Germany ISP nowadays reserve their IPv4 addresses for business customers and provide DS lite access to private customers. You pay a lot more for business contracts.
My router/devices should be accessible using IPv6 as long as I exposed them.
I have a feeling that the Orbi will not be able to fulfil my wishes and I will have to switch my router. AVM is aware of the issues Germany internet users have and is working on this topic. I guess this seems to be a regional problem.
- CrimpOnFeb 10, 2023Guru - Experienced User
I posed the question in the forum for Voxel's third party forum:
https://www.snbforums.com/threads/configure-openvpn-for-ipv6-on-voxel-orbi.83484/unread?new=1
The conclusion is that there is a "good chance" that OpenVPN host will work on the RBR50.
(whether it will work on this specific implementation of IPv6 is unknown.)
Voxel is a software engineer (I believe in Russia - - or not) who reverse engineered the firmware for several Netgear routers: R7500, R7800, R9000, LBR20, and RBR50. He has changed compile options, updated nearly every package to the latest versions, supports Entware, Nano editor, WireGuard, and a lot more. There are README and Quick Start files which explain.
http://www.voxel-firmware.com/Downloads/Voxel/html/orbi.html
The point is that since he unlocked everything, the user can do whatever he wants to configuration files and make them persist over reboots. Those OpenVPN config files can be edited. iptables and ip6tables can be modified. There are references on the OpenVPN web site for what to change to support IPv6 access.
Third party software is not for everyone. I actually have a spare RBR50 that I experiment with and found that Voxel loaded up and ran fine. Many of the features are waaaay beyond me. If you have only a single Orbi and a single ISP modem, it would be a challenge to balance a transition against family needs for internet.
On the topic of accessing Orbi LAN resources directly by public IPv6 address, I remain stymied. On the LAN, I can open LAN web sites, LAN FTP servers just fine. The Orbi Debug setting allows me to ICMP (ping) LAN resources from the internet. But, when I attempt to actually access any LAN resource by IPv6, it fails.
