Markflan
Jan 10, 2020Aspirant
ORBI50 networking
Hi There, I have the ORBI50 router and satellite and we have just built another room at the very back of the garden but being it’s so far away another satellite won’t see the house router/satellite so...
- Jan 10, 2020
You can use a wired backhaul between your RBR50 router and RBS50 satellite. Plug the cable into one of the LAN ports of the router and the first LAN port on the satellite and reboot the satellite. The web UI will show it using a wired backhaul for the satellite in the Attached Devices menu instead of the 5GHz WiFi backhaul.
If possible, do not use a switch between the router and satellite. If you do use a network switch, do not use a green switch (one that saves power by disabling/throttling ports).
See https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System for NG's KB article on doing this.
tomschmidt
Jan 10, 2020Virtuoso
Markflan
Hi there
Many thanks for the quick reply and that’s perfect
Many thanks
Mark
Many thanks
Mark
