MrNoodles
Dec 10, 2017Aspirant
Orbi50 with DOS and remote log in failure causing wifi to die for a minute and come back
For three weeks I had a weird issue where my connection disappears (wireless and wired) maybe 1-3 times a day mostly morning and night. After the wifi signal disappears and comes back less than a min...
- Dec 12, 2017
adeclaxton figure out the problem and my fix after two days hasn't shown any disconnect. Here are my steps to address make sure your firmware is up to date on both the main tower and secondary towers, make sure they are the same version. Then reset the routers to start fresh do not use same wifi name and such.... Also add devices one at a time to see if they are the cause of the disconnects. Overall last 24 hours has been solid.
adeclaxton
Dec 12, 2017Initiate
I have a similiar problem and see the same IP 173.194.76.197 in my logs :smileysad:
MrNoodles
Dec 12, 2017Aspirant
- adeclaxtonDec 12, 2017InitiateMrNoodles I'll give it a try and report back. Mine has just come back online from a disconnect . 2nd one since reading this post
- MrNoodlesDec 19, 2017Aspirant
I want to report back after a week updating firmware on orbi and resetting the device, I have had zero disconnects.
