jefferis
Jul 29, 2023Guide
Orbi54 and Verizon WiFi extender in conflict
So I have an Orbi54 router and RBS50 extender. Attached via Ethernet to the RBS50 extender is a Verizon Network Extender, (installed because of poor Verizon cell service). This satellite reports ha...
CrimpOn
Jul 29, 2023Guru - Experienced User
It would help to clarify the exact product numbers:
- With the Orbi satellites having product number RBS50 (S for "satellite"), the ORBI54 is probably an RBR50 (R for "router"). This will appear on the product label on the bottom of the case.
(At the factory, Orbi units are given WiFi names (SSIDs) composed of the letters O-R-B-I plus a random two digit number. This will lower the chance that two neighbors will purchase units that broadcast identical WiFi names. Many customers choose to change the WiFi name to something more personal during the setup process. - The model number of that Verizon 4G LTE unit is????
It is not entirely clear what would be the purpose of connecting the Verizon LTE unit to the Orbi network
If the goal is to improve Verizon LTE telephone service inside the house, then the Verizon unit should not require a connection to the home WiFi network.
Powerless
Jul 30, 2023Aspirant
It appears that the Verizon extender might be causing interference with your Wi-Fi connections, leading to the spotty service on your laptop. One possible solution is to try changing the Wi-Fi channels on your Orbi router to minimize the interference. You can access the Orbi interface and navigate to the Wi-Fi settings to make this adjustment. Experiment with different channels to see if it improves the connectivity on your laptop.
- jefferisJul 30, 2023Guide
I have tried a different channel, but it didn't seem to help. I don't know what channel the Network Extender is using though. It doesn't say in the software interface.
