Knorske
Apr 18, 2020Aspirant
ORBI60 - Need to reinstall
Made a foolish move. Told my computer to "go back to factory settings." I now have some Microsoft router, rather than ORBI60. How can I get back to ORBI60!! Thank you.
Knorske
Yes. It is an ORBI60, and I installed it with the same name (and used the supplied password). I have a DELL desktop, running Windows 10. Naturally, the computer reverted to Microsoft (ouch, ouch). I, too, appreciate my ORBI60 and the one ORBI60 satellite. I just need to "get back" to them, away from Microsoft.
I will appreciate any assistance!
Thank you for your very prompt response.
CrimpOn
Apr 18, 2020Guru - Experienced User
Knorske wrote:Yes. It is an ORBI60, and I installed it with the same name (and used the supplied password). I have a DELL desktop, running Windows 10.
On Wiindows, there should be an icon in the lower right of the screen that can be clicked to bring up a list of available WiFi networks, and then select ORBI60 from them. If there's no icon, then perhaps the reset turned off the WiFi adapter? On the Control Panel, click on Network and Sharing Center, and click "Change Adapter Settings" on the left menu. There should be an ethernet card and a WiFi device.
