pcottle
Aug 10, 2020Aspirant
ORBI68 RBR20 intermittent connection issues
I have an Orbi68 RBR20 with one satellite. I am haivng an issue where the internet signal intermittently drops out and takes several minutes to come back up. I have tried downloading the latest firmware (2.5.1.16) and performing a full factory reset. All of the devices that are having an issue are on the 5GHz network.
I am connected to a Motorola SURFBoard SB6141 cable modem.
Some other settings I have adjusted (based on other questions on this forum):
2.4GHz channel: 6
2.4GHz Transmit Power control: 75%*
5GHz channel: 48 (Wifi Analyzer shows me as the only router on that channel nearby)
5GHz Transmit Power control: 75%*
UPnP: off
Implicit Beamforming: On
MU-MIMO: Off
Fast Roaming: Off
DaisyChain Topology: Off
Logging: DoS logs filtered out
IPv6: disabled
* Spacing from base to satellite is ~2m, but on different floors of the house. Power reduced to try and avoid switching connections between base and satellite
Thanks in advance for any help!
2m is too close. 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
