Platty
Jan 16, 2022Aspirant
Orbi72 - rear mimo port?
Can anyone help me with information on this router? The round port mext to the SIM slot I thisnk is a TS9 for MIMO antenna as there is another one on the other side. Is this correct and can anyon...
- Jan 16, 2022
This looks a lot like a Netgear LM1200 LTE modem, which does have two T9 antenna ports.
https://www.downloads.netgear.com/files/GDC/LM1200/LM1200_DS.pdf
There are lots of places on the internet that sell MIMO antennas with two T9 connectors.
Netgear even sells an antenna:
CrimpOn
Jan 16, 2022Guru - Experienced User
Is there another label on the bottom?
- PlattyJan 16, 2022Aspirant
Only the MAC and serial number
- CrimpOnJan 16, 2022Guru - Experienced User
ORBI72 is the WiFi names that was assigned to the router at the factory ( they run from ORBI01 to ORBI99).
OK, but what about the ports on the rear?
I cannot find any info on them onthe internet
Thank you, would be good for info on the router I have, however I accept this, thank you.
