Jerry0806
Jun 24, 2021Aspirant
Orbi96 with 2 satellites. I am having difficulty maintaining connectivity. Is ORBI working properly?
Orbi96 is located next to my modem. One satellite is on the lower level, a second satellite is located in the loft. My ISP is Viasat, a satellite dish provider. I want to learn if the Orbi96 is workin...
Jun 25, 2021Guru - Experienced User
What Orbi model # id you have? RBK##?
What is the model# of the Internet Service Providers modem/ONT the NG router is connected too? There a build in router and wifi here by chance?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, Circle, Traffic Meter.
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
Jerry0806 wrote:
Orbi96 is located next to my modem. One satellite is on the lower level, a second satellite is located in the loft. My ISP is Viasat, a satellite dish provider. I want to learn if the Orbi96 is working properly. How do I do this?
