golfport
Jun 24, 2023Follower
ORBI98 power adapter
Which power supply adapter should I be using? I misplaced the original.
golfport wrote:
Which power supply adapter should I be using? I misplaced the original.Netgear does not, it seems, sell replacement power adapters. Any generic adapter will work. Just get one with the right volts, enough amps and a tip with the right (+/-) polarity and dimensions to fit your hardware.
The details you need should be on the old adapter, on a label on the device itself and in its manual.
You can find suitable adapters in all the usual places. Some will even list compatibility with different Netgear hardware.
Some generic adapters come with a set of tips that will fit a range of different devices.
These things are pretty common, so first check to see if you have something compatible lying around.
