jimontherock
Jul 09, 2020Follower
ORBI98 (RBR40) password
After some connection issues, I reset my Orbi98. Now I can't set a new password. It won't let me access the login if I'm not connected thru the orbi, but I can't connect thru the orbi without a passw...
Jul 09, 2020Guru - Experienced User
Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in for 15 seconds then let go. Wait for the WHITE led to slowly pulsate on top of the RBR, then log in to orbilogin.com using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on.
