JPTPKE
Jul 30, 2018Follower
OrbiAC3000 ethernet ports not working
I installed an Orbi AC3000 RBK50 router and 2 RBS50 Satellites. Wifi works great with an extensive Ring security cam setup. However, I connected my previous hardwired devices (TVs, receiver, Dish H...
Jul 30, 2018Guru - Experienced User
Has all other devices been powered OFF, then connected to the routers LAN ports, then powered on?
Ensure all devices are set up Automatic IP addressing and not using a Static IP address.
What is the Mfr and model# of these switches? Power them OFF as well then back on. Then plug everything back into them.
What is the distance between the router and satellites?
Disable Daisy chain on the router, apply and reboot.
