CrimpOn
Mar 30, 2021Guru - Experienced User
Orbie Voice "a Zombie"?
This morning I discovered that devices connected to my Orbi RBS40V were not responding. I find the situation confusing and seek suggestions about how to diagnose the problem. There has been no chang...
Did you try tftp or nmrpflash to load an older firmware?
CrimpOn
plemans wrote:Did you try tftp or nmrpflash to load an older firmware?
Not yet. Two of the four IP cameras have "connected". Still cannot ping them, but they stream video to my desktop. The same brand of IP cameras that are not connected to the RBS40V ping.
Trying to decide between:
- Flashing the current RBS40V firmware,
- Flashing the previous RBS40V firmware, or
- Finally giving up on 2.7.2.104 on the router and loading... (what?)
Thanks for the suggestion about nmrpflash. I have not used it before.
- plemansMar 30, 2021Guru - Experienced User
I've used nmrpflash before. works pretty well when I've needed it
