rsorrentino
Oct 02, 2020Aspirant
orbilogin.com 500 Error
Anyone having an issue loading the http://www.routerlogin.net/index.htm page? It renders some text but no buttons. Links at the "bottom" of the page are clickable but main menu items (Home, Internet,...
Mikey94025
Oct 03, 2020Hero
In router mode your Orbi's DHCP is translating orbilogin.com or routerlogin.net into your Orbi's LAN IP. Some browsers may dislike the mismatching security and produce results as described.
I have very occasionally seen the orbilogin.com page render slowly but usually it doesn't not persist. Do you see this all the time? If you access your admin website via http://192.168.1.1 (substitute your Orbi's LAN IP address if not 192.168.1.1) does it still do the same thing?
- rsorrentinoOct 03, 2020Aspirant
Yes, I see this all the time even when I use the IP address
