ericmcgovern
Nov 05, 2016Apprentice
orbilogin.com doesn't work after changing to AP mode
I am using my Orbi in AP mode, and once I switch it over I can no longer reach the Orbi via orbilogin.com. Is this expected?
peteytesting
Nov 05, 2016Hero
ericmcgovern wrote:I am using my Orbi in AP mode, and once I switch it over I can no longer reach the Orbi via orbilogin.com. Is this expected?
can here , just make sure you restart everything so all your devices pick up an ip from the upstream router as the subnet will be different
ericmcgovern
Thanks for the reply - restart all devices (computer, nest, etc.) or restart network gear? Gateway, Orbi, etc.?
- peteytestingNov 06, 2016Hero
restart the lot as it all needs to be reset to obtain the right ip range
