ericmcgovern
Nov 05, 2016Apprentice
orbilogin.com doesn't work after changing to AP mode
I am using my Orbi in AP mode, and once I switch it over I can no longer reach the Orbi via orbilogin.com. Is this expected?
rjbones
Nov 08, 2016Guide
Can you access its GUI using its IP address? If you did not set a static IP on the AP then you might have to check its current IP from the main router's DHCP list. There were some cases that orbilogin.com does not pull up the GUI after setting up the router to AP mode, but sometimes I can still access it using orbilogin.com. Hence, I prefer using the IP address of the AP that I set on it.
- k9kidsNov 09, 2016Guide
Mines in AP mode and I can restart the Orbi without any restart of my Frontier router.
Always able to reach login page and login.
- ericmcgovernNov 09, 2016Apprentice
I have restartred everything and still no dice on getting to the page via orbilogin.com. I have to go into my modem/router from Comcast dig for the IP, and by manually using the IP I can get to it. Not a huge deal because I don't see myself ever really going to the interface, just odd that it doesn't work.
- rjbonesNov 09, 2016Guide
Let's just probably accept that " It may or may NOT work" when router is on AP mode :-).
