Drewmama
May 16, 2022Guide
Orbilogin.com help
I was changing my settings in orbilogin.com to enable daisy chain. When it was about to finish rebooting, it went to a screen that said "Connect to the Orbi Wifi Network" and now I cannot get back int...
May 16, 2022Guru - Experienced User
What Orbi model do you have?
How was the RBS placed? Star formation is most common. Daisy chain is RBS placed out in a line from the RBR.
Try turning OFF the RBS and turn them back on in a different order.
- DrewmamaMay 16, 2022GuideI have a RBK22/RBR20.
I did what you said and it looks like it worked. The reason I wanted to try daisy chain is because my house is a long rectangle. I'm trying a new modem and it's upstairs at one end. I get no coverage at the other end. I put one satellite downstairs at one opposite corner and another satellite downstairs at the other end.- FURRYe38May 17, 2022Guru - Experienced User
This series is one of the few that you can disable the Daisy Chain feature found under Advanced Tab/Advanced Settings/Wireless Settings.
