blakejnd's avatar
blakejnd
orbilogin.com
Anone else have trouble getting into orbilogin.com?  It never logs in.  Just keeps loading.
Thanks in advance!
  • FURRYe38's avatar
    What browser are you using? Try IE11, FF or Opera.
    Does 192.168.1.1 work?
    What is the Mfr and model# of the ISP modem the Orbi is connected too?
    • blakejnd's avatar
      blakejnd
      None seem to work.  Also, once I try to log on, it basically stops all websites from loading.  I have to turn off/on to get it back working...
  • FURRYe38's avatar
  • I was having the same problems as nearly all the posts,dropping isp,wrong password and others
    scanned the WiFi channels and found interference so made adjustments to Orbi and another WiFi I have in the same house separated as many channels as possible and it straightened right out
    no more errors or dropped isp
    • FURRYe38's avatar
      What FW is currently loaded?
      What is the Mfr and model# of the IP modem the Orbi is connected too?
      What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
      MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
