ISST107
Feb 19, 2022Tutor
Orbilogin.com
I can easily login to orbilogin.com using my 2018 Macbook Air. However, if I try with my new Macbook Pro M1 chip I am not able to login. I tried all variations (e.g., orbilogin.net, 10.0.0.1, etc)....
Feb 19, 2022Guru - Experienced User
what error is it giving you?
did you try a different web browser?
- ISST107Feb 21, 2022Tutor
Good morning. There was no error message. Tried numerous browsers and all do the same thing. Just time out. However, if I use my Macbook Air, works fine. Same operating system and same internet. Also tried the othyer ways of logging in (e.g., 10.0.l0.0, 193...etc). Carzy why it won't work on my new laptaop. Only difference must be the Apple Chip? Thanks
