ISST107
Feb 19, 2022Tutor
Orbilogin.com
I can easily login to orbilogin.com using my 2018 Macbook Air. However, if I try with my new Macbook Pro M1 chip I am not able to login. I tried all variations (e.g., orbilogin.net, 10.0.0.1, etc)....
ISST107
Feb 21, 2022Tutor
Good morning. There was no error message. Tried numerous browsers and all do the same thing. Just time out. However, if I use my Macbook Air, works fine. Same operating system and same internet. Also tried the othyer ways of logging in (e.g., 10.0.l0.0, 193...etc). Carzy why it won't work on my new laptaop. Only difference must be the Apple Chip? Thanks
Feb 21, 2022Guru - Experienced User
Try different browsers on the M1?
What OSX versions are you using?
- ISST107Feb 21, 2022Tutor
Hi . I have tried different browsers and I am using monterey (current version) on both Macbook Pro and Air. Dosen't make any sense to me. Thanks
Crazy stuff. Just tried again now and it worked. No idea why ...but it works again. Thanks for all of everyone's help.
