JBuddenbrooks
Apr 01, 2019Guide
Orbilogin does not use secure (https) login - why? (RBK50)
Once a month I log in to orbilogin.,com to see if there are any Firmware updates. I've observed that the login URL does not use "https://" meaning that my login is not secure. Is there any reason tha...
Apr 01, 2019Guru - Experienced User
Most router mfrs don't use https on the LAN side UI. Unless someone can hack in from the LAN side to the UI, may not be needed thus why nobody is using https for the UI.
