wyncdavies
Sep 22, 2021Tutor
Orbilogin doesn't work - certificate?
I can no longer log into my RBR50 system with orbilogin.com. I get a page that says I'm not on the wifi (which I am). I have tried three different browsers (Chrome, Safari and Edge) to no avail. I...
CrimpOn
Sep 22, 2021Guru - Experienced User
I always use the Orbi IP address, which in most cases is 192.168.1.1
Modern browsers complain about the Orbi SSL certificate being "Self Signed" the first time I open it. Just locate the place in tiny type that says, "go to this page anyway dammit".
wyncdavies
Sep 22, 2021Tutor
I get the same error when using the IP address.
- CrimpOnSep 22, 2021Guru - Experienced User
Is it correct to assume that other networking activities function as they should? (email, web browsing other sites,etc.)
On Windows, I would open a command window and attempt to ping the router at its IP address ( i.e. in my case ping 192.168.1.1)
Does the Mac have a similar capability?
- wyncdaviesSep 22, 2021Tutor
I can ping the router, no problem.
