wyncdavies
Sep 22, 2021Tutor
Orbilogin doesn't work - certificate?
I can no longer log into my RBR50 system with orbilogin.com. I get a page that says I'm not on the wifi (which I am). I have tried three different browsers (Chrome, Safari and Edge) to no avail. I...
BillYoung
Sep 22, 2021Luminary
wyncdavies:
Silly question time: are you connected to the correct network? If you are connected to a guest network, orbilogin.com and 10.0.0.1 (or 192.168.1.1) will not work.
Hope that helps.
- wyncdaviesSep 22, 2021Tutor
I'm on the right network.
