Lesmor
May 24, 2019Aspirant
orbilogin.net
when viewing my devices using orbilogin.net the page seems to refresh every 3 seconds is this normal? If so why is there also a refresh button?
- May 26, 2019
I have contacted another Orbi RBK30 owner who has confirmed that he is seeing the same behaviour on orbilogin.net " > attached devices
Doing further investigation I found under "Advanced page " > internet port > show statistics that there is indeed a 5 second poll interval
So I am now confident that this is normal behaviour and will close the thread
May 24, 2019Guru - Experienced User
Does this happend with different browsers?
Which Orbi system do you have? RBR##? CBK40?
Lesmor
Hi
First time user here
My model number does not seem to be in the list so I used RBR20 to satisfy the website so
I just installed a Orbi RBK30 which has a RBR40 router and a RBW satellite
I get the same result using my Google Crome or Microsoft Edge browser
the "attached devices" page refreshes every 4 seconds
I also tried netspot which shows 4 Netgear connections with the same Network SSI
2 x 2.4 GHz and 2 x 5 GHz and that page also refreshes every 4 seconds as if it is dropping the connection
My phone also shows 2 Networks with the same SSI only one of them (5 GHz) will connect to the Orbi app
