Lesmor
May 24, 2019Aspirant
orbilogin.net
when viewing my devices using orbilogin.net the page seems to refresh every 3 seconds is this normal? If so why is there also a refresh button?
- May 26, 2019
I have contacted another Orbi RBK30 owner who has confirmed that he is seeing the same behaviour on orbilogin.net " > attached devices
Doing further investigation I found under "Advanced page " > internet port > show statistics that there is indeed a 5 second poll interval
So I am now confident that this is normal behaviour and will close the thread
May 24, 2019Guru - Experienced User
Might try a factory reset on the RBR and setup from scratch...
Be sure to clear all browser caches, exit the browser then log back in.
What FW version is currently loaded?
Lesmor
Firmware is up to date
I was afraid that might be the suggested solution
before I do that can you confirm that the orbilogin.net "attached devices " list should not be refreshing every 4 seconds?
| RBS 40 Firmware | V 2.3.1.58 |
| RBW 30 firmware | V 2.3.0.4 |
- FURRYe38May 24, 2019Guru - Experienced User
I don't believe so...
- LesmorMay 25, 2019Aspirant
Well as suggested I cleared cookies and did a reset and fresh install of my Orbi RBK30 and the "attached devices page" on orbilogin.net still refreshes every 4-5 seconds as if it is doing a Auto rescan or dropping and reconnecting
I also had poor download results from "Speedtest" far far worse than from my original Technicolur router
I did a Orbi reboot which seems to have fixed it for now
I would really like to know if this "attached devices" 5 second refresh on orbilogin.net is normal
- FURRYe38May 26, 2019Guru - Experienced User
I would make contact with NG support and ask about the refresh behavior. That doesn't seem right.
https://www.netgear.com/mynetgear/registration/login.aspx
