studdawg
Dec 07, 2019Aspirant
OrbiLogin requiring contant authentication
For the last couple of months, the web login from my desktop is useless. I can login ok to the orbi but it then constantly asks to reauthenticate. Most times it accepts the credentials but sometime...
Dec 07, 2019Guru - Experienced User
What firmware version are you on? (please don't say the latest)
I know one of the versions had significant issues with this.
If you're on the most current, try factory resetting it and reinstalling.
studdawg
yes, i believe it's the latest. It's an RBR50. Firmware is v2.3.5.30. And i've also noticed a drop in range as well associated with this firmware. So resetting will fix the firmware?
