studdawg
Dec 07, 2019Aspirant
OrbiLogin requiring contant authentication
For the last couple of months, the web login from my desktop is useless. I can login ok to the orbi but it then constantly asks to reauthenticate. Most times it accepts the credentials but sometime...
Dec 08, 2019Guru - Experienced User
Be sure to clear out ALL browser caches before entering into the routers web page. Clear caches then exit the browser then re-open the browser then log in.
Has a factory reset and setup from scratch been performed since last update?
