Teddyp
Apr 05, 2018Aspirant
Orbio rbr 50
Hi I have an issue with my orbio rbr 50 router when I first purchased it over a year ago I had a message on my MacBook telling me my router is not compatible in the uk but I purchased it here I ignore...
Apr 05, 2018Guru - Experienced User
Thats someting you'll have to discuss with NetFlix.
Teddyp
Apr 06, 2018Aspirant
But my MacBook Air says the same would I have to discuss that with Apple too my Netflix still works it just happens occasionally basically my MacBook and Netflix thinks my ip is German it only happens on WiFi I don’t have a vpn and I don’t have the issue when I plug my Bt router back in thanks
