Teddyp
Apr 05, 2018Aspirant
Orbio rbr 50
Hi I have an issue with my orbio rbr 50 router when I first purchased it over a year ago I had a message on my MacBook telling me my router is not compatible in the uk but I purchased it here I ignore...
Apr 06, 2018Guru - Experienced User
You should contact NG support. You may have a wrong region HW for your region and Netflix is detecting this some how. You can see if there is any regional or language settings in the routers web page, Other than this, this is something we can't help with here in the forums. Contact NG support and ask for help and information on this.
