AmitR
Jan 03, 2018NETGEAR Employee Retired
OrbiOS 2.1.1
The Orbi team at NETGEAR is aware that some users are experiencing higher than expected Orbi Router reboots, special characters in WiFi Passwords and WiFi / Internet disconnects. We believe these is...
- Jan 16, 2018
Let me give you a quick update on where NETGEAR is with the OrbiOS.
Just before Christmas break, we paused the distribution of OrbiOS 2.1. Very soon, we're about to restart the distribution of a slightly updated version of the beta (2.1.2). In addition to the major new features introduced in 2.1 (e.g. Circle, Ethernet Backhaul), this firmware is expected to address the high CPU issue, as well as the special character in PSK issue as well as support for the Outdoor Orbi. Check Release Notes for complete list.
We are continuing to work on the issues with Google devices that have been documented in the press (several users have provided links here).
My recommendation is that you should either use the Orbi Mobile App (if you haven't seen it recently, check it out, we've made some major improvements) or the Web UI to check for new firmware or wait until your system gets auto-upgraded.
To answer your question, Stars_fan. When Orbi are connected over Ethernet backhaul, the 5GHz band becomes hot standby.
Orbi Product Management
Greystorm64
Jan 04, 2018Apprentice
Well, I am hoping the Beta pans out, because I am getting to the point of dumping the entire setup.. Router & 2 Satallites.
>>Fixes high CPU utilization on Orbi Router, which could be causing other issues
I have a questions, how does one find the CPU Utilization? The UI/Interface for the RBR & RBS's really don't give anyone the ability to measure anything. I can have it count packets sent & recieved, and reset once a month, but I can't find any other monitor points in the system at all.
I also rolled back all my Orbis to the .74 version... its better, but not what it needs to be.
- fitsnuglyJan 04, 2018Star
Installed the beta and will report. I was having issues with random reboots (vaired from 12 hours to 3-4 days, but would eventually reboot for no reason). Other than that, everything else was good. Connection to the web, speed tests via LAN or Wi-Fi, Circle, satelite connections, devices on the correct band, all were perfect. No Android devices in the household, mostly Apple products (do have 1 Chromecast & 1 Nest Cam though).
Well, I'm at work and just got an email that my Nest Camera is down. Tried to log in remotely and can't. Took like 20 minutes until I could get back in my network remotely, so the reboots are still there.
- bcampbell83Jan 04, 2018Star
*Sigh*. Thanks for the update fitsnugly
- martyfpJan 04, 2018Luminary
Greystorm64 wrote:I have a questions, how does one find the CPU Utilization?
If you go to /debug.htm (i.e. 192.168.1.1/debug.htm) then you will see the CPU utilization near the top of the page
- lowepgJan 04, 2018Apprentice
Ironic you're refering to this latest firmware release as a "beta" given how many problems the last "non-beta" release created.
I rolled back to a stable version and will wait to see if you guys actually tested this one before I install it.
- nXXoJan 04, 2018Apprentice
For my part I think it works well, I just installed the beta version and the problem of connection to the router when we are close to the stellite is fixed.
http://<router_ip_address>/debug.htm
- larryindublinJan 04, 2018Luminary
Why do I hear theme from Jaws in my head while reading this? :-)
Will install this when I get home tonight and see how things go.
average 12% load on router
average 20% load on satellite
