AmitR
Jan 03, 2018NETGEAR Employee Retired
OrbiOS 2.1.1
The Orbi team at NETGEAR is aware that some users are experiencing higher than expected Orbi Router reboots, special characters in WiFi Passwords and WiFi / Internet disconnects. We believe these is...
- Jan 16, 2018
Let me give you a quick update on where NETGEAR is with the OrbiOS.
Just before Christmas break, we paused the distribution of OrbiOS 2.1. Very soon, we're about to restart the distribution of a slightly updated version of the beta (2.1.2). In addition to the major new features introduced in 2.1 (e.g. Circle, Ethernet Backhaul), this firmware is expected to address the high CPU issue, as well as the special character in PSK issue as well as support for the Outdoor Orbi. Check Release Notes for complete list.
We are continuing to work on the issues with Google devices that have been documented in the press (several users have provided links here).
My recommendation is that you should either use the Orbi Mobile App (if you haven't seen it recently, check it out, we've made some major improvements) or the Web UI to check for new firmware or wait until your system gets auto-upgraded.
To answer your question, Stars_fan. When Orbi are connected over Ethernet backhaul, the 5GHz band becomes hot standby.
Orbi Product Management
martyfp
Jan 04, 2018Luminary
Greystorm64 wrote:
I have a questions, how does one find the CPU Utilization?
If you go to /debug.htm (i.e. 192.168.1.1/debug.htm) then you will see the CPU utilization near the top of the page
lowepg
Jan 04, 2018Apprentice
Ironic you're refering to this latest firmware release as a "beta" given how many problems the last "non-beta" release created.
I rolled back to a stable version and will wait to see if you guys actually tested this one before I install it.
- nXXoJan 04, 2018Apprentice
For my part I think it works well, I just installed the beta version and the problem of connection to the router when we are close to the stellite is fixed.
- bcampbell83Jan 04, 2018Star
How long have you been running it for? It would take a solid week of stability for someone to convince me to attempt to upgrade.
- DarrenMJan 05, 2018Sr. NETGEAR Moderator
This beta firmware only fixes the issues that amit posted in bullet points all other issues are still being debugged and worked on to be fixed in upcoming betas and firmware releases.
DarrenM
- njwebJan 06, 2018Luminary
DarrenM wrote:This beta firmware only fixes the issues that amit posted in bullet points all other issues are still being debugged and worked on to be fixed in upcoming betas and firmware releases.
DarrenM
Thanks Darren. When you say only fixes those issues, can I assume KRACK is also considered an "issue" (by your definition) as well, meaning the beta does not include the KRACK patch that 2.1.x.x do, correct?
- Greyhawk68Jan 06, 2018Star
Okay, here goes. I pulled out the Eero, and put the Orbi back in with the new firmware to see how it goes. I want this to work so I can save myself $500 and return the Eero system. That said, if the Orbi isn't any better than it has been, the Eero becomes the permanent fixture. Wish me luck.
-Grey
