AmitR
Jan 03, 2018NETGEAR Employee Retired
OrbiOS 2.1.1
The Orbi team at NETGEAR is aware that some users are experiencing higher than expected Orbi Router reboots, special characters in WiFi Passwords and WiFi / Internet disconnects. We believe these is...
- Jan 16, 2018
Let me give you a quick update on where NETGEAR is with the OrbiOS.
Just before Christmas break, we paused the distribution of OrbiOS 2.1. Very soon, we're about to restart the distribution of a slightly updated version of the beta (2.1.2). In addition to the major new features introduced in 2.1 (e.g. Circle, Ethernet Backhaul), this firmware is expected to address the high CPU issue, as well as the special character in PSK issue as well as support for the Outdoor Orbi. Check Release Notes for complete list.
We are continuing to work on the issues with Google devices that have been documented in the press (several users have provided links here).
My recommendation is that you should either use the Orbi Mobile App (if you haven't seen it recently, check it out, we've made some major improvements) or the Web UI to check for new firmware or wait until your system gets auto-upgraded.
To answer your question, Stars_fan. When Orbi are connected over Ethernet backhaul, the 5GHz band becomes hot standby.
Orbi Product Management
rhester72
Jan 04, 2018Virtuoso
Orbi1Kenobi77 wrote:Upgrded to this latest beta firmware and first thing I have noticed is that devices that are closest to the Satelite and are still connecting to the router...
If you have MU-MIMO enabled (or really just steering of any kind), it can be a funny thing - the dB of a signal literally bouncing off a wall from a far AP can actually be stronger than one of closer proximity.
Orbi1Kenobi77
Jan 04, 2018Guide
Only had Enable Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices enabled.
The rest is as per default settings.
