AmitR
Jan 03, 2018NETGEAR Employee Retired
OrbiOS 2.1.1
The Orbi team at NETGEAR is aware that some users are experiencing higher than expected Orbi Router reboots, special characters in WiFi Passwords and WiFi / Internet disconnects. We believe these is...
- Jan 16, 2018
Let me give you a quick update on where NETGEAR is with the OrbiOS.
Just before Christmas break, we paused the distribution of OrbiOS 2.1. Very soon, we're about to restart the distribution of a slightly updated version of the beta (2.1.2). In addition to the major new features introduced in 2.1 (e.g. Circle, Ethernet Backhaul), this firmware is expected to address the high CPU issue, as well as the special character in PSK issue as well as support for the Outdoor Orbi. Check Release Notes for complete list.
We are continuing to work on the issues with Google devices that have been documented in the press (several users have provided links here).
My recommendation is that you should either use the Orbi Mobile App (if you haven't seen it recently, check it out, we've made some major improvements) or the Web UI to check for new firmware or wait until your system gets auto-upgraded.
To answer your question, Stars_fan. When Orbi are connected over Ethernet backhaul, the 5GHz band becomes hot standby.
Orbi Product Management
orbirick
Jan 04, 2018Apprentice
As regards the update order for a new firmware update, I understand to update the satellites first, then the router last for a manual update. And when I did an online update during my initial setup to update from the factory installed 1.12.0.18 to 2.0.0.74, I did the satellites first, then the router, iirc. Then I was able to manually update from 2.0.0.74 to 2.1.1.16 in the proper order. But I could not manually update straight from 1.12 to 2.1. I had to online update to 2.0 first.
But I'm curious, how does the auto-update process work in that same regard? Does the push update do the satellites first, then the router last?
