AmitR
Jan 03, 2018NETGEAR Employee Retired
OrbiOS 2.1.1
The Orbi team at NETGEAR is aware that some users are experiencing higher than expected Orbi Router reboots, special characters in WiFi Passwords and WiFi / Internet disconnects. We believe these is...
- Jan 16, 2018
Let me give you a quick update on where NETGEAR is with the OrbiOS.
Just before Christmas break, we paused the distribution of OrbiOS 2.1. Very soon, we're about to restart the distribution of a slightly updated version of the beta (2.1.2). In addition to the major new features introduced in 2.1 (e.g. Circle, Ethernet Backhaul), this firmware is expected to address the high CPU issue, as well as the special character in PSK issue as well as support for the Outdoor Orbi. Check Release Notes for complete list.
We are continuing to work on the issues with Google devices that have been documented in the press (several users have provided links here).
My recommendation is that you should either use the Orbi Mobile App (if you haven't seen it recently, check it out, we've made some major improvements) or the Web UI to check for new firmware or wait until your system gets auto-upgraded.
To answer your question, Stars_fan. When Orbi are connected over Ethernet backhaul, the 5GHz band becomes hot standby.
Orbi Product Management
OrbiWANKenobi
Jan 04, 2018Star
This latest beta update (2.1.2.10) has resolved all of the issues I was having with disconnects and with not showing devices connected to my 2 satellites.
- lowepgJan 04, 2018Apprentice
Im re-reading the original message and I just want to confirm this beta does NOT address the bug where orbi wont save special characters in password, correct?
- aazJan 04, 2018Virtuoso
lowepg wrote:Im re-reading the original message and I just want to confirm this beta does NOT address the bug where orbi wont save special characters in password, correct?
That appears to be the case from the message, but if you are on 2.1.1.12 or 2.1.1.16, you don't have anything to lose by trying this one. I tried adding a $ in my guest password and that worked, but I have seen another user has trouble with extremely long passwords still.
- dpaugroJan 04, 2018Tutor
I have just upgraded to 2.1.2.* on RBR40 and RBW30 satellites. Internet connection is stable. CPU observed so far lines up with what others have posted. Will apprise.
My only (tiny) complaint is there is no graphic setting for an assitant device like Echo or Home.
- CotedanJan 05, 2018Apprentice
Unfortunately my experience with the Netgear Orbi will contradict to end tonight.
I installed the latest beta software on the router and the two satellites that I have. It’s seemed to be working mostly well. Tonight I got a child fork error as I tried to open the web browser. Also got the same error when I tride to open it from another laptop and on my iPad.
From that point, Things were disconnecting, wired things were showing up as wireless and vice versa etc. Did a factory reset on all three units. Difficulties continued afterwards.
