AmitR
Jan 03, 2018NETGEAR Employee Retired
OrbiOS 2.1.1
The Orbi team at NETGEAR is aware that some users are experiencing higher than expected Orbi Router reboots, special characters in WiFi Passwords and WiFi / Internet disconnects. We believe these is...
- Jan 16, 2018
Let me give you a quick update on where NETGEAR is with the OrbiOS.
Just before Christmas break, we paused the distribution of OrbiOS 2.1. Very soon, we're about to restart the distribution of a slightly updated version of the beta (2.1.2). In addition to the major new features introduced in 2.1 (e.g. Circle, Ethernet Backhaul), this firmware is expected to address the high CPU issue, as well as the special character in PSK issue as well as support for the Outdoor Orbi. Check Release Notes for complete list.
We are continuing to work on the issues with Google devices that have been documented in the press (several users have provided links here).
My recommendation is that you should either use the Orbi Mobile App (if you haven't seen it recently, check it out, we've made some major improvements) or the Web UI to check for new firmware or wait until your system gets auto-upgraded.
To answer your question, Stars_fan. When Orbi are connected over Ethernet backhaul, the 5GHz band becomes hot standby.
Orbi Product Management
tomsliwowski
Jan 05, 2018Apprentice
Found a bug with firmware V2.1.2.10. None of my port forwarding seems to be working after the update.
I tried removing and re-adding but no joy. :-/
- larryindublinJan 05, 2018Luminary"Found a bug with firmware V2.1.2.10. None of my port forwarding seems to be working after the update.
I tried removing and re-adding but no joy. "
This is the kind of thing (if validated and no very very odd setup) that drives us a little nuts. What sort of testing process doesn't check core functionality like this? I hope it's a one off config issue and not broken across the board. My setup seems pretty stable and it is nice to see what's REALLY connected to each router/satellite.- morrisseysbJan 05, 2018Apprentice
I just checked mine...all 3 of mine ARE working with the beta. i will also add that mine are working with NO-IP dynamic dns service.
- tomsliwowskiJan 05, 2018Apprentice
Checking some more I see that some are working.
For example in the screenshot above, RDP, Plex and Subsonic seem to be working while FTP, Ombi, and the 3 cameras are not. I also noticed I can no longer connect to my OpenVPN server.... :-/
