AmitR
Jan 03, 2018NETGEAR Employee Retired
OrbiOS 2.1.1
The Orbi team at NETGEAR is aware that some users are experiencing higher than expected Orbi Router reboots, special characters in WiFi Passwords and WiFi / Internet disconnects. We believe these is...
- Jan 16, 2018
Let me give you a quick update on where NETGEAR is with the OrbiOS.
Just before Christmas break, we paused the distribution of OrbiOS 2.1. Very soon, we're about to restart the distribution of a slightly updated version of the beta (2.1.2). In addition to the major new features introduced in 2.1 (e.g. Circle, Ethernet Backhaul), this firmware is expected to address the high CPU issue, as well as the special character in PSK issue as well as support for the Outdoor Orbi. Check Release Notes for complete list.
We are continuing to work on the issues with Google devices that have been documented in the press (several users have provided links here).
My recommendation is that you should either use the Orbi Mobile App (if you haven't seen it recently, check it out, we've made some major improvements) or the Web UI to check for new firmware or wait until your system gets auto-upgraded.
To answer your question, Stars_fan. When Orbi are connected over Ethernet backhaul, the 5GHz band becomes hot standby.
Orbi Product Management
aclosedmind
Jan 05, 2018Tutor
Odd behavior for me after upgrading to the beta firmware. I'm in AP mode with wired backhaul between my router and 3 satellites. One satellite now shows ALL wireless devices connected to it. The other two satellites have every WIRED device on my network showing as connected, nothing wireless. The Orbi router does not show any connected satellites, as before. Occasionally during reboots it will briefly show my satellites in the satellite section with a "not connected" message.
aclosedmind
Jan 05, 2018Tutor
Sorry, I should say that it says "disconnected" in backhaul status intermittently. Oddly now I show one satellite as "connected" with an incorrect IP address. I have IP addresses set by MAC address in my router on the 10.0.x.x subnet, but right now it shows that one connected satellite on the 192.168.1.x subnet
