AmitR
Jan 03, 2018NETGEAR Employee Retired
OrbiOS 2.1.1
The Orbi team at NETGEAR is aware that some users are experiencing higher than expected Orbi Router reboots, special characters in WiFi Passwords and WiFi / Internet disconnects. We believe these is...
- Jan 16, 2018
Let me give you a quick update on where NETGEAR is with the OrbiOS.
Just before Christmas break, we paused the distribution of OrbiOS 2.1. Very soon, we're about to restart the distribution of a slightly updated version of the beta (2.1.2). In addition to the major new features introduced in 2.1 (e.g. Circle, Ethernet Backhaul), this firmware is expected to address the high CPU issue, as well as the special character in PSK issue as well as support for the Outdoor Orbi. Check Release Notes for complete list.
We are continuing to work on the issues with Google devices that have been documented in the press (several users have provided links here).
My recommendation is that you should either use the Orbi Mobile App (if you haven't seen it recently, check it out, we've made some major improvements) or the Web UI to check for new firmware or wait until your system gets auto-upgraded.
To answer your question, Stars_fan. When Orbi are connected over Ethernet backhaul, the 5GHz band becomes hot standby.
Orbi Product Management
ktd
Jan 07, 2018Apprentice
Just saw this theread and installed 2.1.2 after having massive problems with 2.1.16. I really hope this beta will fix most of the disconnections we have had latly.
larryindublin
Jan 07, 2018Luminary
ktd wrote:Just saw this theread and installed 2.1.2 after having massive problems with 2.1.16. I really hope this beta will fix most of the disconnections we have had latly.
Just remember this beta is only supposed to address the specific things they called out in the release post. It’s NOT supposed to be a stable, final release with everything fixed.
