AmitR
Jan 04, 2018NETGEAR Employee Retired
OrbiOS 2.1.1
The Orbi team at NETGEAR is aware that some users are experiencing higher than expected Orbi Router reboots, special characters in WiFi Passwords and WiFi / Internet disconnects. We believe these is...
- Jan 17, 2018
Let me give you a quick update on where NETGEAR is with the OrbiOS.
Just before Christmas break, we paused the distribution of OrbiOS 2.1. Very soon, we're about to restart the distribution of a slightly updated version of the beta (2.1.2). In addition to the major new features introduced in 2.1 (e.g. Circle, Ethernet Backhaul), this firmware is expected to address the high CPU issue, as well as the special character in PSK issue as well as support for the Outdoor Orbi. Check Release Notes for complete list.
We are continuing to work on the issues with Google devices that have been documented in the press (several users have provided links here).
My recommendation is that you should either use the Orbi Mobile App (if you haven't seen it recently, check it out, we've made some major improvements) or the Web UI to check for new firmware or wait until your system gets auto-upgraded.
To answer your question, Stars_fan. When Orbi are connected over Ethernet backhaul, the 5GHz band becomes hot standby.
Orbi Product Management
madbrain
Jan 08, 2018Luminary
Amit,
How many Orbi reboots should the the users expect ? Shouldn't it be zero ???
Very fed up with Orbi here. And I went back to my old R7000 due to experiencing these issues.
AmitR wrote:The Orbi team at NETGEAR is aware that some users are experiencing higher than expected Orbi Router reboots, special characters in WiFi Passwords and WiFi / Internet disconnects. We believe these issues are related to the OrbiOS 2.1.1 firmware. We are actively working to address these issues, and expect to fix them with a firmware upgrade soon. In the meantime, we’re temporarily suspending auto-upgrading users to OrbiOS 2.1.1.
jmschnur923
The Orbi app says my kp is 10.0.0.1
it is not I am in AP mode and the address is a 192.168 .x.x variant?
why the wrong IP address?
- BlcklabJan 09, 2018ApprenticeI downgraded to 1.11.0.20 and it looks like it ran an auto update back to .74
- bcampbell83Jan 09, 2018Star
Blcklab This post has a link that walks you through how to disable auto-updates. https://community.netgear.com/t5/Orbi/Firmware-V2-1-1-16-auto-update/m-p/1478149/highlight/true#M20130
- BlcklabJan 09, 2018ApprenticeThanks. I might. Netgear reported they had frozen auto updates, and .74 doesn't update on its own, but I guess 1.xx trips things up and updates on it's own. Tried twice and that's what happened, almost as fast as the Orbi configured. It got online, found the satellite then moments later updated itself.
I bought Orbi to simplify my home network and eliminate dead spots and it worked great.
Now it's a daily hassle
