AmitR
Jan 03, 2018NETGEAR Employee Retired
OrbiOS 2.1.1
The Orbi team at NETGEAR is aware that some users are experiencing higher than expected Orbi Router reboots, special characters in WiFi Passwords and WiFi / Internet disconnects. We believe these is...
- Jan 16, 2018
Let me give you a quick update on where NETGEAR is with the OrbiOS.
Just before Christmas break, we paused the distribution of OrbiOS 2.1. Very soon, we're about to restart the distribution of a slightly updated version of the beta (2.1.2). In addition to the major new features introduced in 2.1 (e.g. Circle, Ethernet Backhaul), this firmware is expected to address the high CPU issue, as well as the special character in PSK issue as well as support for the Outdoor Orbi. Check Release Notes for complete list.
We are continuing to work on the issues with Google devices that have been documented in the press (several users have provided links here).
My recommendation is that you should either use the Orbi Mobile App (if you haven't seen it recently, check it out, we've made some major improvements) or the Web UI to check for new firmware or wait until your system gets auto-upgraded.
To answer your question, Stars_fan. When Orbi are connected over Ethernet backhaul, the 5GHz band becomes hot standby.
Orbi Product Management
Richard1864
Jan 11, 2018Luminary
wase4711 wrote:the eero forum isnt active because there arent as many issues as there are with the Orbi; people only post to complain, not compliment
No, most don't use the Eero forum because most Eero users DON'T KNOW IT EXISTS! It also isn't monitored by their tech support team; if you read the posts there, you'd see that mentioned many times by their SINGLE employee who moderates the page. Eero also never really answers any questions posed there by customers either. Anyone with issues is told to CALL THEIR TECHICAL SUPPORT. I've used Eero since it first came out, and it is not perfect, nor is any networking device. I've been on their forum since that was launched too, and I would not recommend it to anyone looking for help.
Oh, and you can' just go by post titles on Eero's forum to tell if Android issues are there or not, you have to actually read them; thee are more than 300 posts under various titles about users having issues with Android and Eero, and none mention Android in the post titles.
Richard1864
An article mentioning Android 8 causing wifi issues, and mentioning that Google is working on the issue. Samsung, LG, Motorola, and LG all have have similar complaints on their forums.
The issue seems to be quite widespread, with reports on Google's Pixel Phone Help forum , reddit , and Netgear's forums . Most accounts of problems seem to be coming from people using Netgear's Orbi routers, but other reports are trickling in from those with other mesh systems, including routers by Cisco and eero, with a small number people using non-mesh access points affected as well.
https://hk.saowen.com/a/3850999a52d59ad1b0ac031e5e28204a04a70287a131c8f909e370643bb2a674
- tomsliwowskiJan 11, 2018Apprentice
Here is the original article link without the dodgy saowen.com links:
That said, I've had 0 reboot issues on my RBK50 kit and my Pixel XL running 8.0 or 8.1
- newbebJan 14, 2018TutorI found a few article this morning where it looks as if there is a problem with the Google Cast protocol and android devices waking from sleep mode across multiple router vendors. The longer a device is in sleep, the more discovery packets it sends when it wakes up, into the 100,000s.
Here is the article that I found that seems to tie it together: https://www.myce.com/news/confirmed-issue-google-cast-causes-temporarily-wifi-drops-around-world-834....
It looks like there might be other issues with Google cast devices and MDNS packets as well like: http://www.androidpolice.com/2018/01/12/google-home-max-appears-killing-wifi-networks/.
I do have a Chromecast on my network, but I so I might unbox my Orbi again and see if that is the culprit... - JMU1998Jan 14, 2018Luminary
Anyone aware if a new Beta is going to be released so we can test it if better than the current ?
- robertcdhJan 14, 2018Apprentice
I had one of these Google devices on my network in November with no noticeable reboots. However, I added 3 more devices on my network at about the time the reboots became a problem. TP-Link resolved the issue with a router firmware update. Netgear, will you please look into this?
I'm going to see if there's a workaround other than removing the devices from the network.
Thanks newbeb!
