AmitR
Jan 04, 2018NETGEAR Employee Retired
OrbiOS 2.1.1
The Orbi team at NETGEAR is aware that some users are experiencing higher than expected Orbi Router reboots, special characters in WiFi Passwords and WiFi / Internet disconnects. We believe these is...
- Jan 17, 2018
Let me give you a quick update on where NETGEAR is with the OrbiOS.
Just before Christmas break, we paused the distribution of OrbiOS 2.1. Very soon, we're about to restart the distribution of a slightly updated version of the beta (2.1.2). In addition to the major new features introduced in 2.1 (e.g. Circle, Ethernet Backhaul), this firmware is expected to address the high CPU issue, as well as the special character in PSK issue as well as support for the Outdoor Orbi. Check Release Notes for complete list.
We are continuing to work on the issues with Google devices that have been documented in the press (several users have provided links here).
My recommendation is that you should either use the Orbi Mobile App (if you haven't seen it recently, check it out, we've made some major improvements) or the Web UI to check for new firmware or wait until your system gets auto-upgraded.
To answer your question, Stars_fan. When Orbi are connected over Ethernet backhaul, the 5GHz band becomes hot standby.
Orbi Product Management
madbrain
Jan 13, 2018Luminary
lowepg wrote:What are the major differences with the Pro?
im interested. I have to admit though- part of me hates the idea of rewarding Netgear with more business because the standard orbis are such a cluster-&&*&^&*
Yeah, I have got to say also, if they don't fix the Orbis we paid for, they are never going to see another dollar from me.
They need to fix their existing product line first.
MrX911
Jan 13, 2018Apprentice
OK I've moaned alot about the last 2 firmwares fior several months to the extent that I went out and trialed Amflifi and Google, both were 100% stable and I decided on the Amplifi and stuck the Orbi away. I think it only fair i report sonething positive back:
Then the latest beta came out and I had some spare time.
I have to say that I have not had a single drop in the last 2 weeks. The only thing that is not working for me is Daisy Chain but I have Good wifi backhaul on 3 satallites.
I'm running 60 cliients at peak mainly Apple, Amazon, CCTV but no Android devices other than Android on a couple of 4k TVs.
All devices are reporting correct attachment too.
The Amplifi is now boxed up and my retrun window with that is 31st Jan. Crossing fingers that things only improve and netgear learn some valuable lesssons too.
