AmitR
Jan 04, 2018NETGEAR Employee Retired
OrbiOS 2.1.1
The Orbi team at NETGEAR is aware that some users are experiencing higher than expected Orbi Router reboots, special characters in WiFi Passwords and WiFi / Internet disconnects. We believe these is...
- Jan 17, 2018
Let me give you a quick update on where NETGEAR is with the OrbiOS.
Just before Christmas break, we paused the distribution of OrbiOS 2.1. Very soon, we're about to restart the distribution of a slightly updated version of the beta (2.1.2). In addition to the major new features introduced in 2.1 (e.g. Circle, Ethernet Backhaul), this firmware is expected to address the high CPU issue, as well as the special character in PSK issue as well as support for the Outdoor Orbi. Check Release Notes for complete list.
We are continuing to work on the issues with Google devices that have been documented in the press (several users have provided links here).
My recommendation is that you should either use the Orbi Mobile App (if you haven't seen it recently, check it out, we've made some major improvements) or the Web UI to check for new firmware or wait until your system gets auto-upgraded.
To answer your question, Stars_fan. When Orbi are connected over Ethernet backhaul, the 5GHz band becomes hot standby.
Orbi Product Management
wase4711
Jan 13, 2018Luminary
firmware update as soon as I got it setup...
An update, I have 4- 4k tv's in the house; right now, watching 8k you tube videos on 2 of them, 4kuhd Netflix on another, and streaming 4k Kodi on another...NEVER was I able to do that with any of the previous things I tested, and no bufferring, stuttering, drops, or anything weird on any of the tv's. all connected via wifi..
We may have a winner here finally, after weeks of testing various products..
tvc15
Jan 13, 2018Aspirant
Wase4711
I'm at V2.0.0.74 with an RBK50 router and two RBS50 Satellites that have been installed for a few months. When I installed my Ring Doorbell 2 I began experiecing dropped Internet connections, unable to access the Orbi Router, etc. I've read multiple people noting that same problem in the forum and I just wondered if you have a Ring Doorbell installed and are not experiencing these issues?
