AmitR
Jan 03, 2018NETGEAR Employee Retired
OrbiOS 2.1.1
The Orbi team at NETGEAR is aware that some users are experiencing higher than expected Orbi Router reboots, special characters in WiFi Passwords and WiFi / Internet disconnects. We believe these is...
- Jan 16, 2018
Let me give you a quick update on where NETGEAR is with the OrbiOS.
Just before Christmas break, we paused the distribution of OrbiOS 2.1. Very soon, we're about to restart the distribution of a slightly updated version of the beta (2.1.2). In addition to the major new features introduced in 2.1 (e.g. Circle, Ethernet Backhaul), this firmware is expected to address the high CPU issue, as well as the special character in PSK issue as well as support for the Outdoor Orbi. Check Release Notes for complete list.
We are continuing to work on the issues with Google devices that have been documented in the press (several users have provided links here).
My recommendation is that you should either use the Orbi Mobile App (if you haven't seen it recently, check it out, we've made some major improvements) or the Web UI to check for new firmware or wait until your system gets auto-upgraded.
To answer your question, Stars_fan. When Orbi are connected over Ethernet backhaul, the 5GHz band becomes hot standby.
Orbi Product Management
aaz
Jan 14, 2018Virtuoso
You never want to have a router behind another router that is handling internet routing. That's known as double-natting and causes problems with a lot of applicaitons.
The Router that is behind an active router on the internet should always be an AP only, unless you know why you want to double NAT and are trying to achieve something very specific such as isolating an application or set of users.
jmschnur923
Jan 14, 2018Luminary
Using AP mode and the latest beta, I get same internet connection speeds using WIFI from all satellites and the router. This is the same speed I get hard wired from the Fios router which has the WiFi turned off ~85 up and down I measure using speakeasy and speed test. I use both IPhone and IPad I get the same results with my hard wired PC. Jitter is low and I am getting 0% loss in my tests.
- wase4711Jan 14, 2018Luminary
I have 1 gig cox service, and my faster wifi speeds are never more than 500 megs up or down with the orbi or orbi pro; any way to improve this, or is this the best you can expect?
using AP mode or router mode, plugged into the cox netgear ac1750 router they provide
- madbrainJan 14, 2018Luminary
wase4711 wrote:I have 1 gig cox service, and my faster wifi speeds are never more than 500 megs up or down with the orbi or orbi pro; any way to improve this, or is this the best you can expect?
Depending on distance from your device to the AP, 500 mbit is probably close to the best you can expect. Have you tried software that uses multiple streams, or doing transfers from more than one wifi device at once to measure speed ?
- guzzijasonJan 14, 2018Apprentice
Yeah, the Orbi uses 2x2 radios for the 5 GHz fronthaul connections, which has a theoretical limit of ~866 Mbps. You are unlikely to ever see anything close to that limit in real-world usage. 500-550 Mbps should be pretty typical.
yeah, even if I stand next to the router or satalite, I never get more than about 340mb speeds to any device, and, when I measure the actual speed to the orbi itself, its in the 400-500mb range..
Too bad there is no way to get closer to 700 or 800 megs wirelessly; it would be nice to use that 1 gig speed I pay for with Cox!
- st_shawJan 14, 2018Master
No. That's as fast as Orbi's WiFi will go. Orbi's link speed is 866 Mbps and you will only get 50% to 60% of the link speed as throughput under ideal conditions. Why would you need more speed than that anyway?
need more speed? no, not really..
WANT more speed? Always!
Since I pay for 1 gig speed, I would like to get as much as possible, so if I can tweak/move/adjust something to improve speeds, great. If not, thats ok too..
