AmitR
Jan 03, 2018NETGEAR Employee Retired
OrbiOS 2.1.1
The Orbi team at NETGEAR is aware that some users are experiencing higher than expected Orbi Router reboots, special characters in WiFi Passwords and WiFi / Internet disconnects. We believe these is...
- Jan 16, 2018
Let me give you a quick update on where NETGEAR is with the OrbiOS.
Just before Christmas break, we paused the distribution of OrbiOS 2.1. Very soon, we're about to restart the distribution of a slightly updated version of the beta (2.1.2). In addition to the major new features introduced in 2.1 (e.g. Circle, Ethernet Backhaul), this firmware is expected to address the high CPU issue, as well as the special character in PSK issue as well as support for the Outdoor Orbi. Check Release Notes for complete list.
We are continuing to work on the issues with Google devices that have been documented in the press (several users have provided links here).
My recommendation is that you should either use the Orbi Mobile App (if you haven't seen it recently, check it out, we've made some major improvements) or the Web UI to check for new firmware or wait until your system gets auto-upgraded.
To answer your question, Stars_fan. When Orbi are connected over Ethernet backhaul, the 5GHz band becomes hot standby.
Orbi Product Management
dpdurst
Jan 15, 2018Luminary
fcwest wrote:Does anyone have working download links for the latest 2.1.2 beta (or newer) for the RBR50, RBS50, and the RBW30?
The links at the beginning of this thread result in corrupted disc images whether I download them from Windows or Mac browsers.
Just PM you a link
Orbipain
Jan 15, 2018Guide
I have been a happy user, of Netgear products, for many years now. At least until this product. Having spent over 40 years dealing with enterprise level security systems software I also understand patches and firmware updates to the Nth degree. The Orbi product firmware problems to date are a clear indicator of poor product testing overall. Does Netgear not have emulation stress testing equipment, and procedures, to properly evaluate product before release? This is an extrodinary contrast to your other product quality. People or procedures? In any case I will not update firmware any further until I see reliable indicators that it works properly! In fact I am seriously considering getting rid of it.
