AmitR
Jan 03, 2018NETGEAR Employee Retired
OrbiOS 2.1.1
The Orbi team at NETGEAR is aware that some users are experiencing higher than expected Orbi Router reboots, special characters in WiFi Passwords and WiFi / Internet disconnects. We believe these is...
- Jan 16, 2018
Let me give you a quick update on where NETGEAR is with the OrbiOS.
Just before Christmas break, we paused the distribution of OrbiOS 2.1. Very soon, we're about to restart the distribution of a slightly updated version of the beta (2.1.2). In addition to the major new features introduced in 2.1 (e.g. Circle, Ethernet Backhaul), this firmware is expected to address the high CPU issue, as well as the special character in PSK issue as well as support for the Outdoor Orbi. Check Release Notes for complete list.
We are continuing to work on the issues with Google devices that have been documented in the press (several users have provided links here).
My recommendation is that you should either use the Orbi Mobile App (if you haven't seen it recently, check it out, we've made some major improvements) or the Web UI to check for new firmware or wait until your system gets auto-upgraded.
To answer your question, Stars_fan. When Orbi are connected over Ethernet backhaul, the 5GHz band becomes hot standby.
Orbi Product Management
sdunnin
Jan 15, 2018Guide
FWIW I've been running on 2.1.1.16 since whenever it auto updated last without any issues. CPU Usage is < 10% and uptime is currently 24 days. I am looking forward to the attached devices page showing the correct connection bug getting fixed though. We have very few android devices on out network (an older Acer tablet, and an Acer chromebook). Everything else is Windows, Apple, or an IOT device. Have had a some freqent random disconnects with only 2 (my wife's iphone 6 and ipad 2) of the half dozen Apple devices. Other than that have not noticed any other issues with the current FW version.
Orbipain
Jan 15, 2018Guide
Have yet to see an accurate representation of what is actually connected to the RBKS on the latest firmware release.
