AmitR
Jan 03, 2018NETGEAR Employee Retired
OrbiOS 2.1.1
The Orbi team at NETGEAR is aware that some users are experiencing higher than expected Orbi Router reboots, special characters in WiFi Passwords and WiFi / Internet disconnects. We believe these is...
- Jan 16, 2018
Let me give you a quick update on where NETGEAR is with the OrbiOS.
Just before Christmas break, we paused the distribution of OrbiOS 2.1. Very soon, we're about to restart the distribution of a slightly updated version of the beta (2.1.2). In addition to the major new features introduced in 2.1 (e.g. Circle, Ethernet Backhaul), this firmware is expected to address the high CPU issue, as well as the special character in PSK issue as well as support for the Outdoor Orbi. Check Release Notes for complete list.
We are continuing to work on the issues with Google devices that have been documented in the press (several users have provided links here).
My recommendation is that you should either use the Orbi Mobile App (if you haven't seen it recently, check it out, we've made some major improvements) or the Web UI to check for new firmware or wait until your system gets auto-upgraded.
To answer your question, Stars_fan. When Orbi are connected over Ethernet backhaul, the 5GHz band becomes hot standby.
Orbi Product Management
Stars_fan
Jan 16, 2018Aspirant
Is the expected behavior for a wired backhaul to disable the satellite radio? If I unplug the cable 5G connects and enables the satelites radio again.
I'm not having any of the reboot issues. The only android in my house is my A1E Sony TV but that's wired.
Also having a $ in your SSID password is not fixed in the beta.
aaz
Jan 16, 2018Virtuoso
I have a beta that fixes the $ in password issue. For some reason they have not put it out to a wider beta but it has been stable for me for about a week. I don't think it fixes the Android issue and as I said before it's likely anyone that had a $ in their password removed it by now so that is not as big an issue. Still if you want that try PM the moderators.
