AmitR
Jan 03, 2018NETGEAR Employee Retired
OrbiOS 2.1.1
The Orbi team at NETGEAR is aware that some users are experiencing higher than expected Orbi Router reboots, special characters in WiFi Passwords and WiFi / Internet disconnects. We believe these is...
- Jan 16, 2018
Let me give you a quick update on where NETGEAR is with the OrbiOS.
Just before Christmas break, we paused the distribution of OrbiOS 2.1. Very soon, we're about to restart the distribution of a slightly updated version of the beta (2.1.2). In addition to the major new features introduced in 2.1 (e.g. Circle, Ethernet Backhaul), this firmware is expected to address the high CPU issue, as well as the special character in PSK issue as well as support for the Outdoor Orbi. Check Release Notes for complete list.
We are continuing to work on the issues with Google devices that have been documented in the press (several users have provided links here).
My recommendation is that you should either use the Orbi Mobile App (if you haven't seen it recently, check it out, we've made some major improvements) or the Web UI to check for new firmware or wait until your system gets auto-upgraded.
To answer your question, Stars_fan. When Orbi are connected over Ethernet backhaul, the 5GHz band becomes hot standby.
Orbi Product Management
tvc15
Jan 17, 2018Aspirant
Is there a way to eliminate 2.4ghz on my router but keep it active on the satellites? My Samsung S7 Edge continually connects to 2.4ghz when I have a perfect 5ghz signal. Unfortunately, Samsung took away the ability to configure which one the phone connects to!
DarrenM
Jan 17, 2018Sr. NETGEAR Moderator
We have released 2.1.2.18 offically please update to this firmware either via auto update or manual update on the support page. Please start a new thread if you have any issues related to the latest firmware.
http://www.netgear.com/support/product/orbi.aspx
DarrenM
