AmitR
May 07, 2018NETGEAR Employee Retired
OrbiOS 2.1.4 + Homekit
We’ve been monitoring issues that some users have experienced on OrbiOS 2.1.4 with Apple Homekit. In response, to those customers, we’re releasing firmware that provides a temporary work around to c...
CDuda34
May 08, 2018Aspirant
I downloaded the firmware files per the links provided (RBS50-V2.1.4.10-0430-dbg.img and RBR50-V2.1.4.10-0430-dbg.img). However when I go to upload load (I am using the manual firmeware instruction provided) the satellite formware I get the following message:
This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product.
My router and satellites are on V2.1.4.10 currently. Any ideas? I have 35 homekit device so this issue is killing me.
- usahaleMay 08, 2018Star
Delete the RBS download and redo the download. It worked OK for me.
- CDuda34May 08, 2018Aspirant
Ok, I re-downloaded the firmware files, but needed to restart the satellites and router before they could be installed. However after the reboot, the install went as described in the instructions. With the new firmware, my Homekit seems stable. I'll have to see how my automations run over the next couple of days or so.
Netgear,
If you haven't already, invest in some homekit hardware and test before releasing! That being said, thank you for the firmware patch.
